servis wd M9003w-a
  • #26541
    cab
    Hi got a fault thats got me. When set on a dry program it runs for 11mins then advances thru the stop position to the next program which it carries out. If a wash program is set it works ok. Cant find anything down to earth. Replaced module and main timer but fault is still there. If I turn the drier timer to zero it switches off and doesnt advance thru to wash.
    Any ideas?
    😕 cab
    #210537
    MickGeorge
    Re: servis wd M9003w-a
    Sounds like it is overheating for some reason.. but why it dosent do it at the end of a wash prog beats me..
    Have you checked the air flow and condeser for any blockages?
    Mick
    #210538
    cab
    yep, I would expect any problem with over heating would just cause it to end the program, but not to advance thru to next wash prog. I fitted the bits, ran it and it moved on after 11 mins, switched the machine off megad elements etc, switched it straight back on, so it would have still been hot, and it ran for 11 mins again! weird.
    cab :bounce:
    #210539
    timdowning
    The main timer knob isn’t 180 degrees out of allignment???
    OC or SC on drier valve??
