ServisCaress 1500 A
  • #26689
    K9cop
    Hi All,
    I really, really need to take the rubber door seal out of this machine and either give it a good clean or replace it, can’t get it out though, appears to be permantly bonded to the drum. Any ideas/info/suggestions gratefully received. Thanks.
    K9
    #211079
    Re: ServisCaress 1500 A
    You’ll need to undo the screw clamp band first, or it’ll never come off. If the gasket has turned black with mould, replacement is your only real option. Post the model number and we’ll be able to identify the one required for you.
    Power off, please.
