SES oven lamp.i
  • #103294
    chuffy
    Bit of a strange one,but I have come across this issue a few times in the past.
    A SES oven lamp won’t screw into the socket because it’s too loose.
    I can recall on odd occasions having to remove a treaded sleeve from the old lamp then fit over the new lamp thread to increase its diameter by a couple of mm so it’s a snug fit in the socket.
    Unfortunately the customer has thrown away the old lamp so the aforementioned sleeve is not present and I’ve no idea where to source one from.
    Cheers.
    Noel.
    #492525
    sounds like the brass sleeve which is part of the lampholder has come out with the lamp
    can you get a new lamp assembly
    chuffy
    Yes Dave you can get a replacement lamp assy about £30.
    But it’s an old built in double oven in a very awkward place so would turn into a rather expensive job just to replace a lamp.
    The customer is not too bothered….neither am I.
    #492527
    chuffy
    Dave it’s not a brass sleeve it’s chrome coloured the same colour as the lamp thread.
    #492528
    chuffy wrote:Dave it’s not a brass sleeve it’s chrome coloured the same colour as the lamp thread.
    same idea though
    brass is probably too expensive when you make thousands
