I have a new Indesit washing machine model IWD 51231.
Under Setting the Temperature the manual states that “the machine will automatically prevent you from selecting a temperature which is higher than the maximum value set for each wash cycle”.
Well it doesn’t physically prevent me doing this so am I to assume it means that if I set it too high for the cycle it will ignore the temperature setting and only heat to the maximum for the wash cycle setting? So if I set the temperature knob to the maximum (90)and leave it on that permanently then will I automatically get the correct maximum for each cycle I subsequently use?
Sorry if this seems a dumb question but I don’t think the manual is clear on what it actually means.
