sevis m6766w queer fault during cycle
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries sevis m6766w queer fault during cycle
  • #51472
    keithwilliams
    i’m pretty sure i know the answer to this but i’ll ask any way.
    select a wash cycle and it starts with the usual clunk from fill valve when it powers up. it has a think about it and the fills and starts washing. after about 10 mins during the heat phase it suddenly and repeatedly starts clunking from fill valve about evry second or so.
    my gut feeling is board fault but i’m hoping it’s something much cheaper.
    thanks
    #308210
    pup
    Re: sevis m6766w queer fault during cycle
    sound like b oard to me
    #308211
    Heater’s on after 10 minutes – earth leak?
    EMW and QER both sort the pcbs out for sensible money if that proves to be the problem.
    PGS
    Ive had a few of these where the interlock has been at fault
    #308213
    keithwilliams
    i know what you mean pgs but in this case the door is locked and due to other functions ( fills rotates begins heating etc)i can only assume that it is o.k. also if selector is turned to off then back on the problem disappears for about another 10 mins then comes back.
    #308214
    robbra
    I had very similar on a Hoover washer, stuttering valve and found if I put plug in a different socket it disappeared. Probably the module but just a suggestion
    Rob
    #308215
    deltra
    how about pressure switch, wanting to fill to next level ❓
    #308216
    robbo1973
    servis had a big problem with door locks causing the valve to pulse mainly after a cycle had finished,check the lock and if it is a larger blue type then change it as these where problematic.
    #308217
    PGS
    here here Robbo i mentioned interlock 4messages ago.
