sgs43a22gb/01
  • #45380
    pup
    does this macine has same impleller jug as well,this machine is overfilling thanks
    #285503
    Re: sgs43a22gb/01
    It does not appear to have an impellor jug. There’s a metering tank on left side and a mushroom in base.
    Mike.
    #285504
    pup
    Re: sgs43a22gb/01
    thanks a lot 😆
    #285505
    nomadPaul
    HOWEVER….it does have the level float in the sump base to sort out the water level. Take out the filter and its at approx the 4 o’clock position under a small grey cover. . It’ll probably be all gunged up and not lifting properly hence the overfill
