SGS43C12GB/08 Lower spray arm fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SGS43C12GB/08 Lower spray arm fault
  • #22426
    Spon
    I know that there is a similar spin arm fault but think that there is a different cause. Basically, the lower spinner does not move at all. The top works fine with high pressure. The water heats fine and drains with no problems. I have taken off the lower arm and it is clear of any muck. I then put a cup over the hole and ran a cycle. The cup did not move so no water is coming through. I have then blown down the spin arm hole with a piece of hose and did not feel any blockage. The filters are clean but I my family are not the best at cleaning food off plates before dishwashing.
    The washer is 2 months out of warranty but cannot afford the £65 callout fee minus parts for a fix I might be able do myself… with a bit of help from this forum.
    What could be causing a problem?
    How could it be fixed?
    Can someone recommend a cheaper engineer if one is needed?
    Cheers
    #194898
    gegsy
    Re: SGS43C12GB/08 Lower spin arm fault
    Hi Spon
    I would imagine the water diverter on the heater unit and/or module is at fault.
    You say 2 months out of guarantee, when did you buy it??
    The worst it can be is March 2004, but BSH are usually pretty lenient, and may do a deal on the spares 😀 and you pay the labour.
    superfix
    You WILL need your purchase receipt to show to engineer. At best I would guess you may get 30{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} off the price of the part as things have tightened up considerably lately.
    #194900
    Spon
    It was given to me by my landlord but according to Bosch the warranty ran out in August and they did not offer me any further help. Can I buy and fit water diverter or module myself and what sort of cost might I be looking at. Thanks so far..
    #194901
    Heater/diverter assembly is £70 odd, plus VAT and P+P. It is a complete nightmare to fit if you’ve never tried working on one of these before – I’m a pro and I struggle. Two courses of action: use the repairs@ link below to find an independent in your area. Hourly rate may well be lower, but I imagine they will charge for at least an hour and a half’s work at least. Discuss when making contact to avoid surprises. Secondly, the Bosch charge is a one off, so it looks a bit more attractive given the time element involved.
    If you are going to do it yourself, we can’t walk you through the job blow by blow – check the Forum Rules as to what we can tell you. Patience and lots of diagrams is the secret.
    Good luck,
    Spon
    Re: SGS43C12GB/08 Lower spray arm fault
    Thanks guys.
    Bosch support stated £65 callout for 30 mins and then £4 for every 6 minutes, with parts being added as well. So I might be looking at £100 plus parts. I am not sure how much the washer is worth but I may as well buy a new one.
    Is the cost likely to be cheaper going somewhere other than Bosch?
