SGS43C12GB/08 salt sensor
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SGS43C12GB/08 salt sensor
  • #57007
    Wibbly
    Salt chamber is empty but the salt low light doesn’t come on. I guess bulb may be blown or PCB fault, but is there as sensor that can maybe be cleaned/replaced? If so where is it? How does the salt sensor work?
    #329532
    CJAPeterborough
    Re: SGS43C12GB/08 salt sensor
    Is the salt sensor switched on?
    I recall that you can disable the addition of salt with a power on and
    reset button B or A? being pressed at the same time.
    Again I think they are fairly crude sensor devices and work based on density
    If you check the bosch support site for diagrams of your model it mentions
    a magnet component just beside the softener unit…maybe this has stuck?
    #329533
    Wibbly
    The light remains off even with no salt. Anyone know how to switch the feature ON again (button combinations)? That would seem a very simple place to start, in case it’s been switched off 🙂
    It could be any state at the moment as I just moved in, and cleared the drain pump of of bits of china (I think). All works well, and seems pretty clean. Would be nice to get it all working though…
    #329534
    CJAPeterborough
    can download the manual here
    http://www.bosch-home.co.uk/quick-links … nuals.html
    #329535
    Wibbly
    Sadly, that issue isn’t covered in the maunuals 🙁
    #329536
    It most certainly is included in the document link CJAPeterborough gave you in fact. Go back to the document download page for your exact model (EnrNo) and open the 2nd .pdf file. And Salt Adjustment is the first option on the list. 😀
    #329537
    Wibbly
    So it is! Thanks (both) 🙂
