Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › sgs45c02gb/02 bosch d/w
- This topic has 18 replies, 7 voices, and was last updated 15 years, 11 months ago by
Galway.
April 17, 2010 at 6:11 pm #54034
Galway
ParticipantHi all
this d/w seems to have a funny noise from the motor it is a higher pitched sound than normal.customer had insured it when buying it from curry’s and they sent someone out and he told her it needs a new motor.but now curries have decided to just replace the d/w by giving her a voucher for the value of it.she asked me to hace a look so i am wondering if there are any motor faults with these.
thanks
niallApril 17, 2010 at 6:14 pm #318129gegsy
ParticipantRe: sgs45c02gb/02 bosch d/w
The water seals do break down as with any.
Not the nicest of jobs but very do able within an hour 🙂Greg
April 17, 2010 at 6:26 pm #318130Galway
thanks for the quick reply, would this cause the whinning noise .
thanks niallApril 17, 2010 at 8:36 pm #318131nomadPaul
ParticipantIf the seal leaks on the motor , water gets into the motor and bearings causing quite heavy corrosion. The whining is the bearings running really roughly.
April 18, 2010 at 12:15 am #318132leavemetogetonwithit
I think I remember the puffin, I mean penguin, saying you could replace the bearing easily enough on many of these motors.
Mike.April 18, 2010 at 9:41 am #318133Galway
thanks i will order a seal kit and seee how i get on
thanks
niallApril 18, 2010 at 10:20 am #318134chezza
leavemetogetonwithit wrote:I think I remember the puffin, I mean penguin, saying you could replace the bearing easily enough on many of these motors.
Mike.no, wasnt me 😆 must have been mr p 😆
April 18, 2010 at 11:27 am #318135Penguin45
Motor unit will disassemble if you need to replace the bearings. You need to mark the shaft to ensure that you locate the new ones correctly.
April 18, 2010 at 2:50 pm #318136Galway
do the seal kits come with a new bearing
thanks NiallApril 18, 2010 at 4:59 pm #318137Penguin45
Nope – about £1 from your local transmission specialist.
April 18, 2010 at 6:57 pm #318138leavemetogetonwithit
Or http://www.simplybearings.co.uk if you don’t live in a big town.
Mike.April 19, 2010 at 7:50 am #318139Martin
or…….Qualtex BRG20……….or Whirlpool 481252028082…………or Connect……or Masterpart……just ask for a 608ZZ Ball Race Bearing – tell them Martin sent you! 😀 😉
April 22, 2010 at 12:47 pm #318140Galway
does the old bearing come out easy
April 22, 2010 at 2:56 pm #318141Martin
Galway wrote:does the old bearing come out easy
Yes but requires a generous dose of WD40, patience to let the effect work, then careful extraction using a 2 claw bearing extraction tool. 🙂
April 23, 2010 at 9:06 am #318142Galway
anything else work dont have a 2 claw bearing extraction tool 💡
