Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SGS45E02GB/05 Instaneous heater failed yet again
- This topic has 12 replies, 6 voices, and was last updated 17 years, 5 months ago by
Twoten.
October 28, 2008 at 9:01 pm #40583
Twoten
ParticipantJust had a call back to this machine.
1st heater went June 06
2nd went Jan 07
Now 3rd gone!Due to the time between the first 2 going I started this topic http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=20082&start=0&postdays=0&postorder=asc&highlight=bosch+instantaneous+heater
Customer says she regularly tops up the salt and always scrapes the plates as well as cleans the filter.
When I fitted the last elements I cleaned the float chamber hose to sump.
I’ve fitted quite a few of these now and never had problems like this.
Anything I’ve missed?October 28, 2008 at 10:50 pm #266905smartin
ParticipantRe: SGS45E02GB/05 Instaneous heater failed yet again
if the machine is over foaming can cause premature failure ie; 5 in one tabs + salt + rinse aid or if she pre washes in sink and dont wash all of fairy off of pans can have the same result.
October 28, 2008 at 11:18 pm #266906Twoten
ParticipantRe: SGS45E02GB/05 Instantaneous heater failed yet again
She stooped using the 5 in 1 tabs a while ago because I suspected it could be a problem.
I don’t think she pre-washes in the sink, I only suggest customers scrape the plates off before putting in the dishwasher.
October 28, 2008 at 11:33 pm #266907admin
KeymasterRe: SGS45E02GB/05 Instaneous heater failed yet again
I had the same happen this year on a bosh dishwasher 6 months after fitting element
It went again . I have fitted these on lots of other machines and never had one go again.???. I did not have to pay for the element again, got a replacement under g tee
But had to fit the bl…..dy thing for free… 🙁😕 But…….. we have a bosh dishwasher at home and when I was in the kitchen the other day it was making a odd sound so I opened the door to find a plastic jug that we use had been pushed over buy the water jets and had then been filled up with water.from the spraying arms which had then made the machine under fill in the sump by almost one pint ..thus making the water pressure lower being sprayed around…. Could this of happen on the machines that we fixed ,and made the element run to hot…….??? this happend again with the same jug so i now make sure its on the top rack and wedge it in so it stays upside down….
canufixit..
October 29, 2008 at 12:27 am #266908nomadPaul
ParticipantIf the water level’s too low , the heater shouldn’t switch on as there’s not enough water pressure to ativate the membrane of the pressure swutch that is intergrated into the IWH .
We have had a few probs with repeated failures on some Bosch D/W’s but no-one’s really sure why .
October 29, 2008 at 8:49 am #266909Twoten
ParticipantnomadPaul wrote:If the water level’s too low , the heater shouldn’t switch on as there’s not enough water pressure to ativate the membrane of the pressure swutch that is intergrated into the IWH .
This was my thinking too, also I would have thought the same would apply if the machine foamed up during the wash.
October 29, 2008 at 9:28 am #266910Martin
So far, touch wood, I’ve not had a recall after fitting an instanteneous water heater but I’m wondering if it is associated with those heaters fitted with water point divertor units?
You guys that have had problems, were they all perhaps units of this type I wonder? 😕
October 29, 2008 at 9:48 am #266911Twoten
Martin wrote:water point divertor units?
What is the ‘Water point divertor unit’?
October 29, 2008 at 11:08 am #266912nomadPaul
Twoten wrote:
Martin wrote:
water point divertor units?What is the ‘Water point divertor unit’?
Its the motor/disc in the heater box that switches between the top and bottom spray arms .
I’ve never really noticed but as it seems to occur in later models , which all tend to have the water point , i suppose that may be true. I will have to keep an eye on it.
I will say that i’ven only had about 3 or 4 machines in 3 years that have had a repeated heater failure.
October 29, 2008 at 12:42 pm #266913Twoten
nomadPaul wrote:Its the motor/disc in the heater box that switches between the top and bottom spray arms .
I thought it might be that but most of the instantaneous heaters I’ve fitted have had the divertor fitted.
October 29, 2008 at 1:03 pm #266914Martin
Twoten wrote:I thought it might be that but most of the instantaneous heaters I’ve fitted have had the divertor fitted.
Interesting. 😉
If you take any faulty element apart you will notice that they almost always fail at the coiled end. The end that’s under the metal plate and the part that usually gets a coating of limescale (in hard water areas of course 😉 )
The water point diverter is also at that end and it is the hottest and weakest point in any immersion element as a rule too.
Another point to possibly note is whether or not the customer frequently uses the hottest longest cycle as the norm so to speak? That would confirm at least the failure more prone to longer hotter wash selection…maybe?
October 30, 2008 at 10:05 am #266915boselecta
Participanthad one of these do this when i worked for comet, replaced the pressure pot and seemed to cure it. My thinking was the the blocked pressure pot causes the high fill microswitch to stay on activating the heater.
October 30, 2008 at 3:22 pm #266916Martin
Participantboselecta wrote:My thinking was the the blocked pressure pot causes the high fill microswitch to stay on activating the heater.
Great theory but I’m afraid that’s not right as the power to the heater is controlled at all times via the microswitch on the heater unit. To my certain knowledge they never give problems. 😉
