sgs45e08gb/45 bosch dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries sgs45e08gb/45 bosch dishwasher
  • #55409
    HotDog
    going to this dishwasher fri customer select a prog say 42min on display will go to 27 min then sticks but will eventually go to 1min and stays she
    says it does not heat will this be o/c heater or bad connections on board they have been on the net for info and been told fault on pressure sw any advice welcome 😆
    #323581
    Re: sgs45e08gb/45 bosch dishwasher
    Most common cause of this is all of the innards gunged up Cliff. not enough water enters the machine to trip the flow meter microswitch in the heater box.
    Take off the left hand (from front ) side and the plinth and check the transfer pipe that you can see bottom left at the front and the float chamber/pressure switch assembly at the side.
    If the very top, left hand corner of the large plastic fill matrix has signs of dark sludge then that will also cause the problem, that one is very difficult to clean and a new chamber is the best option.
    You can megger the element from the other side.
    If you enter “Bosch AND one AND minute” into the search facility in that exact format but without the quotes you will get plenty of reading.
    #323582
    HotDog
    thanks jim will do
    #323583
    HotDog
    blocked transfer pipe did the trick thanks jim
