SGV5613GB/12
  • #29812
    rocker
    Have no heat, traced neg line to heater but no postive line in, it seems to orginate from pcb, can anyone confirm this, as may need to order part, or is it posible to repair re-solder?. Thanks John.
    #224814
    gegsy
    Re: SGV5613GB/12
    Live feed from PCB through 85deg stat then onto heater.
    Neutral side is from mains switch and is fed to heater through the safety microswitch on heater.
    rocker
    Re: SGV5613GB/12
    greg is the stat fitted to door as traced positive cable back to lower part of door then goes inside door,found no stat in line yet. john
    #224816
    gegsy
    Re: SGV5613GB/12
    Stat will be on top of heater unit
    gegsy
    Re: SGV5613GB/12
    Will send bumff over for your perusal 😉
