Home › Forums › Public Support Forums › Buying Advice › Shallow built in oven? Who are Econolux?
- This topic has 6 replies, 3 voices, and was last updated 3 years, 2 months ago by
milleniumaire.
January 28, 2023 at 6:20 pm #101652
milleniumaire
ParticipantI’m looking to replace an old Diplomat ADP3120 built in oven. The door seal and probably the thermostat have failed and this oven was “inherited” when our house was purchased 7 years ago, so its time for a modern replacement.
Easier said than done!
Thanks to a poorly position gas pipe for the hob that sits above the oven and what appear to be shallow kitchen units, I’m really struggling to find an oven that will fit the space. The old Diplomat is only 520mm deep, but importantly, it has a sloped back top, which clears the gas pipe, allowing it to fit. The slope essentially reduces the depth of the top of the oven to 410mm deep, gradually increasing, where it reaches the maximum depth of 520mm at 110mm down from the top.
I have found a shallow oven; the Econolux ART28812, which is only 498mm deep and this is adequate for the 540mm depth of the cupboard, except for the top 65mm which only allows for 470mm deep due to the gas pipe connection to the hob. Many ovens I’ve looked at have a “cut out” at the top back, possibly to allow for gas pipes.
Unfortunately, I can’t find any detailed dimensions for the Econolux ART28812 and therefore can’t say for sure it will fit. There are also no photos of the back of the oven, which might give an indication of a “cut out”.
It’s also a make I’ve never heard of and I can’t seem to find any information, even on the UK Whitegoods website.
Who owns the Econolux brand? Where can I get some detailed measurements/drawings from? Is the brand any good?
Can anyone recommend a shallow built in oven? The maximum depth available in the cupboard is 540mm, but reduces to 470mm for the top 65mm due to the gas pipe connection to the hob.
January 28, 2023 at 7:37 pm #485580matrixresonator
ParticipantI’d recommend getting the gas pipe moved if thats possible, otherwise you’ll be revistiting this issue again.
January 28, 2023 at 9:36 pm #485581electrofix
Moderatormatrixresonator wrote:I’d recommend getting the gas pipe moved if thats possible, otherwise you’ll be revistiting this issue again.
Agreed
safer and more practical
January 29, 2023 at 8:06 pm #485582milleniumaire
ParticipantThe problem with moving the gas pipe is that I’m not sure exactly how it could be moved to provide more room. I was going to upload some photos showing the gas pipe position within the cooker cupboard enclosure, but I have no idea how to upload photos to ukwhitegoods forums and all my attempts failed, so I gave up!
Instead, I’ll post the issue on the diynot forum, which is easier to use!
January 29, 2023 at 8:12 pm #485583electrofix
Moderatorbecause of server space pic sizes are limited
so best to upload to a pic site like google pics and then post a public linkDave
January 29, 2023 at 8:54 pm #485584milleniumaire
Participantelectrofix wrote:because of server space pic sizes are limited
Dave, I tried using URL’s from my Google Photos account, which has an upload of all the photos from my Android phone, but any URL I supplied was rejected. with an “Invalid File” error. Not really very helpful! I also tried looking for a forum entry that might explain how to use the “Image” facility, but couldn’t find any help.
January 29, 2023 at 9:52 pm #485585electrofix
Moderatorthe image has to under 2Mb to save server cost
to use the google account it has to be a public link as the link you use will need a password
Dave -
