Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Sharp Condenser Dryer model KD-NCD9S7PW9
- This topic has 24 replies, 4 voices, and was last updated 2 years, 2 months ago by
seanbabtiste.
January 11, 2024 at 1:53 pm #102494
seanbabtiste
ParticipantThis dryers driving me mad , it comes with error EO6 so iv changed all the stats including at the front and it makes no difference, if i have it on timed dry itll run fine for the whole hour , but it seems on other programmes itll throw a wobbly and pop up the error , if you then , turn it off and back on itll run fine , Im just wondering whether theres a service mode or diagnostic mode for it I can run, the dryers mint about 2yrs old Tia experts
January 11, 2024 at 2:53 pm #489147kwatt
KeymasterCan you check that model please as KD-NCD9S7PW9 doesn’t appear to be valid?
January 11, 2024 at 4:03 pm #489148seanbabtiste
ParticipantHi , your quite right it should be KD-NCB9S7PW9 and again i ran twice this morning on “timed dry” and its worked fine, but it seems popping it on another setting it throws it EO6 Thanks
January 11, 2024 at 4:29 pm #489149kwatt
KeymasterE06 means the door NTC connector is disconnected or, I imagine, not being seen by the board.
January 11, 2024 at 4:44 pm #489150seanbabtiste
ParticipantThanks for that, i know i can test the front door NTC so if thats working ok , then the error must be the board, however the confusing thing is , itll work without fault on the timed programmes, , or is that just “luck” would you say cheers
January 11, 2024 at 4:48 pm #489151kwatt
KeymasterOn that front I don’t know to be honest.
January 11, 2024 at 8:56 pm #489152electrofix
Moderatoryou need to check resistance is around 12K at 20 degrees C
January 12, 2024 at 12:25 am #489153seanbabtiste
Participantcheers will do
January 12, 2024 at 11:21 am #489154seanbabtiste
ParticipantSwapped the NTC for one I had here, and the dryers performing A1, i tested the on I took out and its giving me those readings, also when on radiator and in fridge the values change so I imagine its working fine , but like i say the one i popped in seems to be behaving its self , drying some towels , when progs finished ill check values again
January 12, 2024 at 12:34 pm #489155seanbabtiste
Participantseanbabtiste wrote:Swapped the NTC for one I had here, and the dryers performing A1, i tested the on I took out and its giving me those readings, also when on radiator and in fridge the values change so I imagine its working fine , but like i say the one i popped in seems to be behaving its self , drying some towels , when progs finished ill check values again
So as near as damn it , the NTC i swapped into the dryer is at those values and the dryer performed through its 90min cycle fine, im going to do one last 75 cycle and if it dosnt pop up the error, ill pronounce it healthy, , I can only think the previous ntc while the readings were right– it itself wasn’t
So cheers for the advice , reading NTC are they all pretty much generic regarding the settings they have , or is each mfr NTC of different settings?
January 12, 2024 at 1:06 pm #489156electrofix
Moderatorthe only way you can be certain of the differences is to measure each one at the same temp
the 2 ntc’s in this machine have different resistance’s at 20 degrees
January 13, 2024 at 5:11 pm #489157seanbabtiste
Participantelectrofix wrote:the only way you can be certain of the differences is to measure each one at the same temp
Grrrrr, no its still not happy , Dave where is the other NTC, in this pain in the A**e dryer, hopefully not a drum out jobby Tia
January 13, 2024 at 5:19 pm #489158electrofix
Moderatorits easier to show a pic
that one rated at 12k at 20 degrees as opposed to the one on the heater which is 19.5K at 20 degrees
January 13, 2024 at 5:38 pm #489159seanbabtiste
ParticipantThanks so on the element theres 3 im going to call them thermostats far right is a restttable one, so the other NTC is one? of the others then yes thx
January 16, 2024 at 2:11 pm #489160seanbabtiste
ParticipantThe ntc at fronts reading right and the one on the heater element, the other 2 stats are brand new on the element, driving me mad ist load wet towels this morning worked fine till dry , 2nd load eo6 arggggggg any thoughts guys
