We have a Sharp R795 microwave and the top grill element has failed. Replacing this would obviously require the outer casing to be removed but whenever I read about microwave repairs it says anything that requires the cabinet to be opened up should be done by a repair agent.
My question is therefore, by “cabinet” do they mean the actual oven lining or the white outer casing? Logically I would have thought it was ok to remove the outer casing but I’d be grateful for any advice
