Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › sharp qw-gt34f463i f5 error
- This topic has 19 replies, 2 voices, and was last updated 6 years, 1 month ago by
Kieran Delahunt.
February 24, 2020 at 7:17 pm #97250
Kieran Delahunt
ParticipantHi all,
I have a Sharp qw-gt34f463i which throws an F5 error which is lack of water. When I detach the hose the pressure is fine. I took the water softener off to see if it was clogged but there’s nothing I can see. Nothing will go through it though.
Do I need a new softener unit and how would I prevent this happening again if so?
February 25, 2020 at 10:33 am #466660kwatt
KeymasterThat error is listed as:
F5 :: Inadequate water supply
Make sure the water input tap is totally open and that there is no water cut.
Close the water input tap, separate the water input hose from the tap and clean the filter at the connection end of the hose.
Restart your machine, contact the service if the error resumes.So for whatever reason, it’s not seeing the machine being filled so, water valve or the flow meter on the inlet tank are top suspects.
March 7, 2020 at 12:17 pm #466661Kieran Delahunt
ParticipantThe water valve hasn’t worked, fingers crossed for the flow meter
March 12, 2020 at 9:04 pm #466662Kieran Delahunt
ParticipantHi [USER=”2″]kwatt[/USER] , any other ideas – it’s not getting past the new water valve. I’ve had the hose off the back and set it on a cycle but nothing comes thorugh. Could it be a logic board somewhere?
March 13, 2020 at 12:19 am #466663kwatt
KeymasterThe obvious question is, is water getting to the valve?
Next obvious question, is the valve energised?
March 13, 2020 at 8:42 am #466664Kieran Delahunt
ParticipantThanks K, water is indeed getting to the valve just not past it. I’ll get a multimetre and test the valve but it has to be this. Do you know what could be the issue if there’s no voltage at the valve?
March 13, 2020 at 11:13 am #466665kwatt
KeymasterThe valve is a simple solenoid, it’s open or it’s closed, working or not working, no in-between with them. So, if it gets power and opens that’s really all there is other than a potential blockage of some kind as it’s incredibly rare for a valve to only open partially.
March 13, 2020 at 3:08 pm #466666Kieran Delahunt
ParticipantOkay, I can verify the wires to the valve are not producing anything. What could that be?
March 13, 2020 at 3:16 pm #466667kwatt
KeymasterI’d suspect that’s controlled by the main card in it but to suss that out you need the serial number, multiple versions of it used.
March 13, 2020 at 3:24 pm #466668Kieran Delahunt
ParticipantDo I provide it here or somewhere else?
March 13, 2020 at 3:34 pm #466669kwatt
KeymasterHere is fine.
March 13, 2020 at 4:22 pm #466670Kieran Delahunt
Participant01693668001731420049
March 14, 2020 at 10:22 am #466671Kieran Delahunt
Participant[USER=”2″]kwatt[/USER] More clarification, just to get your opinion. I have a multimeter on the connections to the valve, the reading fluctuates between -10v and 8V from the off. Does that suggest a current leak in the system somewhere and would you think it will be the main PCB still?
March 14, 2020 at 12:09 pm #466672kwatt
KeymasterAll the info for the valve is:
1.5 Water Inlet Valve
Voltage Frequency Total Power Flowrate Resistance
: 220/240 Volt : 50-60 Hz
: 6 W
: 2,5 lt/dk: 3750 ±٪10 Ω ( 20 Co )
Single inlet and single outlet standard single coil solenoid valve. It is assembled to the basement and connect to the airbreak by hose..
So, it needs mains power to operate.
That serial number doesn’t look quite right but it should be this board set used in it:
https://shop.ukwhitegoods.co.uk/dish…rol-module-set
March 24, 2020 at 2:51 pm #466673Kieran Delahunt
ParticipantI’m now just getting an F6 error, is this thing just knackered?
