Re: Sharp R-750 AM (Microwave Oven) – door problem
No, the door would be very expensive. Actually I’m having second thoughts about advocating this as a DIY repair, although you don’t need to touch the dangerous high voltage bits. If you were to assemble the door incorrectly you could end up with harmful microwave leakage. I would always test for microwave leakage after doing any repair on these ovens but you probably won’t have access to a test meter. You might find there is a local appliance repairer or even a TV repairer who can do the repair and/or do the leakage test. You could make an enquiry for the latch at the Shop@ part of this website but they may refuse to supply the part for the reason stated. The latch head only costs a few pounds.
