SHOCKING MODULE
  • #21139
    fk
    😉 Hi guys ! The Hotpoint service agent has just called on us to repair a WD640 in which the Three Phase power module needed replacing.
    Part No. C00099905 . There was a large warning thatstated that the large aluminium heat sink remains live after disconection and under NO CIRCUMSTANCES should the board be removed under 5 minuites after the power is disconected. Just thought there might be a few of you that would find out the hard way.
    #189664
    Re: SHOCKING MODULE
    A well documented warning that has been aired on the boards many times, a repeat of this can do no harm at all though. 8)
    machineman
    Do these mods have to be formatted or do you just bung them in.m
    #189666
    Re: SHOCKING MODULE
    They have the eeproms, just like all the other Indesit electronically controlled machines, they will need to have the correct eeprom fitted, the original replaced or a blank eeprom, reprogrammed with the EMIT enabled laptops I would guess. 😥
    Seamy
    Re: SHOCKING MODULE
    The new Mieles’ mostly have 3 Phase motors in them also so the same applies there. :lesson:
