should sinks be earthed
  • #52699
    mbdas
    Hi 🙂 been to a washer today and repaired it ok but checked the socket and got no earth customer said she had a bloke in to fit new tiles and sink and worktops but found that one of the sockets in the kitchen the earth wire had come out which sorted the earth problem to the washer socket but the sink was not earthed .does the sink need to be ❓
    mark 😕
    #312805
    S1MON
    No it does not need supplementry bonding
    #312806
    Re: should sinks be earthed
    Yes..
    now days with all the plastic pipework thats used…it should be.
    bryan
    #312807
    neilsukwg
    r600a wrote:Yes..
    bryan
    Agree 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} especially if sink is near to washing machine. A quick simple check is to check resistance between appliance (plugged in but not switched on at socket) and the sink or taps if unpainted. should be minimal resistance.
    ie < 0.1
    #312808
    Alex
    All metal sinks and associate metal pipework should be electrically bonded, and an earth path must exist.
    Alex
    #312809
    S1MON
    Supplementary bonding of metal work surfaces, etc, is not a specific requirement of BS 7671. The designer of the electrical installation may, however, perceive there to be an increased shock risk in that particular location and specify additional bonding.
    #312810
    S1MON wrote:Supplementary bonding of metal work surfaces, etc, is not a specific requirement of BS 7671. The designer of the electrical installation may, however, perceive there to be an increased shock risk in that particular location and specify additional bonding.
    I can concur that S1MON has it spot on in that the 17th edition regs DO NOT require additional earth bonding to sinks or work surfaces in a kitchen …correct!:D
    However the water supply taps (if they are copper or lead and not plastic) have to be cross-bonded directly to the incoming mains stop-cock). The same regulation likewise equally applies to utility rooms.
    However they do not apply to shower rooms, wash-rooms/cloakrooms and bathrooms. So if you find (say) a washing machine wedged into a small downstairs cloakroom (as I did recently) and that small sink is not cross-bonded then it darn well should be (even with the old 16th edition regs).
    #312811
    mbdas
    The pipe work is earthed but when the plumber refitted the metal sink he fitted 2 plastic valves which then broke the earth bond to the sink and left a earth wire dangoling free. I spoke to a plumber and he said it was ok but spoke to a sparky and he said it should be earthed as the path had been broken ❓ hence the confusement 😕 😕 so I thought one of you guys may know ❓
    #312812
    mbdas wrote:The pipe work is earthed but when the plumber refitted the metal sink he fitted 2 plastic valves which then broke the earth bond to the sink and left a earth wire dangoling free. I spoke to a plumber and he said it was ok but spoke to a sparky and he said it should be earthed as the path had been broken ❓ hence the confusement 😕 😕 so I thought one of you guys may know ❓
    In this instance the plumber is correct and not the spark. If the water supply line has been switched from copper to plastic (as you appear to suggest when you referred to “2 plastic valves”) the metal sink need not be earthed. However as the plumber has left the existing earth wire dangling free I’m sure it would be a simple task to earth the metal sink to re-establish an existing earth bond if you wish.
    #312813
    mbdas
    yes thats what Ive done but plumber has put willys 😆 into the customer by saying the sink need not be earth coz if she was washing pots and a lighting strike happened she would get zapped :zap:
    #312814
    timdowning
    sell her a thick pair of rubber gloves. Or a dishwasher. 💡
    #312815
    mbdas wrote:yes thats what Ive done but plumber has put willys 😆 into the customer by saying the sink need not be earth coz if she was washing pots and a lighting strike happened she would get zapped :zap:
    Again the plumber is correct because whether the sink was earthed or not and lightening struck whilst she was washing the dishes, she could indeed get zapped. But it’s interesting to note that the chances of getting struck by lightening are around 1 in 3 million. That’s based on being outdoors and unprotected at the time. The chances of your house being zapped are slightly wider odds at 1 in 4.5 million. However, the chances of being in your house and washing the dishes during a lightening strike then the odds are getting far greater at 1 in 75 million.
    Finally, the odds of someone directly, rather than the house they are in, actually being “zapped” by lightening whilst washing the dishes is almost astronomical in proportion to imagine. Bearing in mind that the highest point of the house (i.e the chimney, the TV antenna, roof ridge tiles etc) are the points where lightening will strike (i.e the easiest point to ground). I would venture to guess then that the odds may be somewhere in the region of 1 in 8,000 million?
    So, if you give those somewhat hypothetical statistics some or any credence at all, I would think there’s more chance of the plumber “putting willys into the customer” has more chance of occurring than any of the above, don’t you think? Personally I’m not sure as I’m not a betting man.:twisted:
    #312816
    martinm
    ha ha lol brilliant you should have been a bookmaker
    #312817
    gandh1
    im just mildly concerned about the plumber actually possibly being a pimp…
    #312818
    bigchrisoioi
    think you have to use common sense….i cover my arse every call by completing electrolux safety reports for un earthed sinks……i dont care what the electrics are, i follow the proceedures and cover my backside as a serviceforce engineer……what a world it has become !!!!…sad really
