Shower Pump Noise, Can i reduce the sound?
Home Forums Public Support Forums Help And Support Other Appliances Shower Pump Noise, Can i reduce the sound?
  • #92797
    williamnorman
    I have just had a bath removed and a shower installed and had to have a pump installed to give me a decent shower. We have a low pressure hotwater tank system (according to plumber) and we needed the pump to power the bar mixer shower. Every time I turn on the shower there is a large hummmm from the pump.
    Is there anything that could help reduce the noise?
    William
    #452230
    don
    Re: Shower Pump Noise, Can i reduce the sound?
    Hi William
    We can certainly help on kitchen appliances ( white goods) but sadly not on showers and their associated components.
    I have Just Googled bathroom shower forums and quite a few came up.
    Don
    #452231
    just as an extra. any mechanical device makes noise but the amount of noise it makes is also dependant on how and what it is mounted on. if the pump is mounted on a joist or wooden floor it might well amplify the noise. you could only find this out by mounting the pump on a vibration absorbing material
