Side by side fridge not cold
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Side by side fridge not cold
  • #71262
    krazylegz
    Hi all 🙂
    My whirlpool FRSS2VAF20/0 has given up the chase.
    The freezer is spot on and ice cold, but the fridge just seems warm to me, can’t check the exact temp until I get a thermometer tomorrow, it certainly isn’t the 2c the front is set at.
    I’ve been reading around and I’ve took off the top cover in the fridge, the finson the air diffuser are only slightly open. However I can feel any air blowing in from the fan when I remove the air diffuser.
    Does anyone have any ideas what it could be?
    thanks
    #380518
    Re: Side by side fridge not cold
    The diffuser would be the favourite.
    krazylegz
    Thanks mate. Would I not feel the fan blowing the cold air from the freezer when the diffuser is removed though?
    Sent from my iPhone using fingers and thumbs!
    #380520
    I don’t know what you mean.
    krazylegz
    Correct me if I’m wrong as I’m a novice with fridges.
    Am I correct in thinking that there’s a fan behind the back in the freezer that blows cold air into the fridge through a plastic pipe that connects to the air diffuser?
    What I’m saying is I can’t actually feel any air getting blown through from the said fan when i unscrew the diffuser from the fridge wall
    #380522
    Yes, but if the fan was faulty the freezer wouldn’t be cooling either if memory serves as the same fan drives both.
    krazylegz
    Ah right, thanks for that mate guess I’ll try the evaporator.
    I’ll try and get a thermometer today and actually see what the temperature is in the fridge
    #380524
    krazylegz
    Hi mate, I’ve got a thermometer and the fridge is definately too warm, the front is set to 2c but it’s 10c according to thermometer. The freezer is set to -19c on the front and thermometer says its -20c in there.
    I’ve took the backing off the freezer and it’s not frosted up, can hear the water dripping and hissing onto defrosting pipes, which shows that is working, but the fan isn’t spinning at all. Would that more than likely be the fan itself or the thermostat?
    #380525
    krazylegz
    Ok I tell a lie, just opened the freezer and the fan was spinning
    #380526
    Diffuser or whatever is controlling it. 😉
    krazylegz
    Yeah I think I’ll try a diffuser when I get paid, for now though I’ve took out a few fins from the diffuser to see if helps till I get one
    #380528
    krazylegz
    Thanks for your help mate, I took our the diffuser and the baffle was snapped so it couldn’t open the vents once it closed them, so bought a aluminium one off eBay for for £12 and now it’s fully functioning and holding at 3c nicely…… You’ve saved me a lot of money I haven’t got at the minute….. Thanks again bud 🙂
