Siemans Auto WM12E468 F21 Fault Won’t Reset – Help!!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemans Auto WM12E468 F21 Fault Won’t Reset – Help!!
  • #82521
    laurenceuk
    I have followed the reset procedure given by Martin in response to Mike412’s enquiry:
    “Unplug motor, selector switch off, touch any button, rotate selector. This will awaken module” – in a nutshell.
    This has not worked on this machine. Have I missed something?
    Presume F21 to be a motor issue.
    Could the module be damaged by original fault?
    Thanks,
    Laurence
    #420126
    Re: Siemans Auto WM12E468 F21 Fault Won’t Reset – Help!!
    I assume you have replaced the motor brushes? it can take several attempts to clear but I have never failed to get rid of it eventually.
    #420127
    nomadPaul
    That’s not the correct procedure i think . Try selector switch to off. Turn selector switch to 6 o’clock , hold down spin speed button and turn selector switch one position clock wise. Release spin speed button and then return switch selector to off.
    #420128
    laurenceuk
    Thanks iadom and nomadPaul,
    I appreciate your response, very helpful
    Laurence
    #420129
    laurenceuk
    Thanks nomadPaul, that did the trick.
    Laurence
    #420130
    nomadPaul
    No worries. There’s lots of posts on here on resetting the bsh machines but they can get swallowed up in all the other info available.
