Siemans D/W SN26M253GB/44 How To Release Module? – See Photo
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemans D/W SN26M253GB/44 How To Release Module? – See Photo
  • #79264
    laurenceuk
    Not come across this type of Siemans D/w before with a heat exchange type impellor housing on the motor.
    Complaint of not heating(E09). Measured at plug with red leads – assumed as heater leads – no circuit. (see pic)
    How easy to change? Plus trying to get the module out to get at the motor I found that it seemed locked into the corner at the side and rear casing. I released it from the other points but it just pivots in that corner where it is hidden away by the base moulding.
    Is it just a clip that poking around with a long screwdriver will do the job?
    Any insights appreciated.
    Thanks.
    Laurence
    PS Ignore ‘Bosch’ on pic, it’s ‘Siemens’.
    #408632
    timdowning
    Re: Siemans D/W SN26M253GB/44 How To Release Module? – See P
    There’s been a few posts of late about this style.
    The module will unclip with a bit of jigging. (Kettle lead out of the back, which I’m sure you’ve already done).
    You can then change the motor / heater assy from the same side.
    Make sure the new motor comes with a clamp.
    #408633
    Read this from the manual…….
