Siemans hob EH512502E/01
  • #32181
    clivejameson
    This little fella is a two ring induction hob that’s coming up with Er37 on the display for both rings…anyone got any idea what that means before i end up replacing the main board anyway?
    #234009
    nomadPaul
    Clive , afraid i can’t see that fault code anywhere .
    #234010
    clivejameson
    Re: Siemans hob , a mere snip
    Ok thanks anyway…looks like we’ll have to replace the main pcb, a mere snip at £183 😯
    #234011
    gegsy
    Re: Siemans hob EH512502E/01
    Fault Er** except for Er37 means the touch control has an internal failure ie bolloxed 😀
    So you may only need 429408 and not the main board, still around the £100 with the VAT 😥
    clivejameson
    Very interesting Greg…the problem is this one has two knobs to operate it 😕
    The fault code flashes E then r then 3 then 7 in both ring displays simultaneously so i assumed that was error no.37?
    Does it have a touch board as well then?…i couldn’t get the thing to do anything
    #234013
    gegsy
    Yea i know its got 2 knobs but also has touch control for the “P” Power booster adjacent to each knob.
    Will end you some bedtime reading over should help before you part with your cash 😉
