Siemans MK1440 E6 Error
  • #83478
    daza1
    Hello all. I have a Siemnans MK1440 fully intergrated washer dryer. It completes a cycle and instead of spinning and draining it just continually trys to drain without spinning. Then E6 code comes up. I have stripped it down and visibly checked all the pipes, pump and filter. There is no blockage at all. If i put it on a spin and drain cycle it does this with no issues. Is there anything else i could try. Cheers. Daza
    #422853
    daza1
    Re: Siemans MK1440 E6 Error
    I dont want to appear desperate….but …please please please please please does anyone have an idea
    #422854
    don
    If it’s spinning okay the next thing to check is the filter and pump for blockages. Or it could be the pump is faulty, this can be determined by testing with a multimeter.
    HTH
    Don
    #422855
    daza1
    Don, I have checked all filters pipes and the pump already for blockages and all was fine. I will check the pump with a multimeter. Thanks
    #422856
    daza1
    I have checked the pump. All seems to be working fine. Continuity and pump drains at the end of te cycle????
    #422857
    don
    Even though you say it’s spinning okay have you checked the motor brushes?
    Don
