Siemans SE25A091/GB/01
  • #20558
    goosegreen
    Could any of the Bosch guys remind me how to set the salt useage on the above? Have downloaded manual from Bsh, But its not got the set up procedure listed. Cust has lost the instruction book, As they do.
    Regards
    Goose
    #187489
    gegsy
    Re: Siemans SE25A091/GB/01
    Hi Goose
    Can’t find model you mention so will assume SE25A091GB/17.
    With appliance switched off, press and hold S4 (4th button from the right of display) and then switch on; the current hardness setting will be shown. If you keep pressing S4 again it will increment the hardness setting until desired setting reached.
    Regards
    goosegreen
    Cheers Greg, Will mail on to cust. By the way this machine is the Muts. Total stainless casing even the the cabinet top weighed a ton, And when I removed the SS side panel was astonised to find that it had the nomal pressed steel side panel underneath 😮 Maybe a case of German over engineering, But I know which I prefer to work on.
    Goose
