Got this one no enr sorry. The inlet solenoid on aquastop tap end was oc. Rrplaced aquastop valve and have been back twice to reset the pneumatic valve to make it fill. It works ok when i am there but valve locks out fill after one wash. Have blown up the 3 tubes all seem clear and rodded transfer tube with piece of hose. Not pulled it out yet though.Can anyone help?
Regards Simon
Guessing game time then…… Have you checked the anti flood? Bled the matrix drain tube? Checked the pump not drawing excess current? Err?…what else…..hmmmm….?…scratch, scratch…..PCB tracks?…,float micro switch? Phew!
Managed to decipher worn label SR73230GB/13 FD7304 the one with the salt fill 1/2 way up on the lhs cabinet . Been back again to reset antiflood diaphraghm in valve AGAIN. Filling ok so started wash and sat through whole wash cycle. Watched the foam in matrix build till it was flowing out of matrix and filling the pressure hoses which tripped valve again. Asked about rinse aid never used it and I confirmed tank empty. Drain hose so high under sink no chance of backfilling. Kids asked if they had put washing up liquid in dishwasher.
Actually went out and bought customer Finish powerball tablets and sure enough no foam.
Sat through whole wash again all ok. 3hrs in total spent.
Took some of their tablets to try in my newer bosch dishwasher. At the moment it isn’t spraying water its just foam. opened door and its high.
Tablets? Fairy lemon.
S.
45cm slimline dishwashers will always over foam using a gel tablet. Loose powder is best or a cheap Aldi or Lidl tablet cut in half the way to go! Avoid power balls and other technological rubbish too!
