Hello,
First time here , my problem is as follows I had to clear a blockage at the waste pump , I had to remove the sump to clear the debris ,when i went turned machine back on after reassembling there was a click and an ERROR CODE E:06 ,
anybody here know what error this is and how I can rectify this problem ? please,
Re: Siemans Type SD6P1S dishwasher error code E:06 ? please
Problem resolved thankyou for you’re help Martin ,switch is actualy a sensor located inside top of door ,looks like rinse aid managed to work its magic on the sensor, A quik spray of contact cleaner and a gentle wipe resolved the error.Also door very tricky to refit two plastic inserts near hinges were the culprits.
Thanks Again.
