Re: siemans washer
The floppy handle is the problem , not the door lock. Make sure the machine is switched onto a program , start it so you hear the door lock. Once it starts , wait a few seconds then press the start button again to pause it. You should hear the lock click unlocked. Turn off the dial. Now , if you pull the handle back as much as it goes , shine a torch into where the lock/handle meet and you should see the metal door hook. You can slip a small long flat bladed screwdriver down the side of the hook and twist it to prise open the hook. The door should just pop open
