Siemans washer/dryer wd61 1400gb12
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemans washer/dryer wd61 1400gb12
  • #87669
    davewest
    Hi having trouble with machine leaving small amount of water in the bottom of drum when finished,and cloths are still wet. Everything seems to work fine except when drying only cold air is blown in. Have checked pump , changed brushes, cleaned out plastic box attached to back of drum. Could it be the dryer heating element, if so where do I find it. When washing the water heats up fine .Many thank Dave
    #435598
    Re: Siemans washer/dryer wd61 1400gb12
    The thermal trip has gone on the safety stat fitted on the side of the heater box. And the condenser box on the RHSide is blocked with fluff. You’ll need to removed the bottom corrugated hose to gain access and throughly clean it out!
    #435599
    davewest
    thanks Martin will give it a go Tuesday thanks again Dave
    #435600
    davewest
    Hi Martin , did what you advised and now working as good as new, might even last another 20 years . Many thanks for your help Dave
