siemans washer dryer wk6140gb/13 dryer fault not heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemans washer dryer wk6140gb/13 dryer fault not heat
  • #78078
    funkyboogy
    dryer motor comes on ok , but no 240 to element , and valve
    looks like no neut feed to element , traced 240 on the live side right up to element.
    any pointers as to where to start with this ..
    thanks ally
    #404382
    funkyboogy
    Re: siemans washer dryer wk6140gb/13 dryer fault not heat
    martin ???
    #404383
    funkyboogy wrote:martin ???
    The control unit switches on the neutral side Ally so you will always get a live to each component. Have you got continuity through the valve coil and the heater?
    #404384
    funkyboogy
    HI MARTIN
    yes cont through both components, the fan comes on i ran it for 10 minutes checked for voltage to components but nothing to neut side ..
    ally
    #404385
    Hmmm? Looks like we need to investigate more closely. What’s the CORRECT Enr number of this beast?
    #404386
    funkyboogy
    ENR WK61420GB/13 FD8303 400880
    cheers ally
    #404387
    funkyboogy wrote:ENR WK61420GB/13 FD8303 400880
    That’s better, no wonder I couldn’t find it! 😀
    Replace the NTC (part no. 00175369) on the top dryer duct should solve the problem I reckon. 😉
    #404388
    funkyboogy
    hi martin cheers i did wonder about that ?
    will order up and let you know how i get on ..
    ally
    #404389
    That should sort it Ally :tup:
