Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › siemans wm16s493
- This topic has 13 replies, 5 voices, and was last updated 14 years, 6 months ago by
funkyboogy.
September 20, 2011 at 6:26 pm #65178
funkyboogy
Participantwm sticks with 1 minute to go ..no water in it so it has drained
f27 fault comes up ..customer switches of – puts back on and door opens ok
anyone know what this could be
cheers ally
September 20, 2011 at 7:31 pm #359391Martin
ParticipantRe: Re: siemans wm16s493
funkyboogy wrote:anyone know what this could be
IIRC it is an inlet valve problem?
September 20, 2011 at 10:23 pm #359392suedehead1
ParticipantRe: siemans wm16s493
could be a blocked pressure switch tube or faulty pressure switch.
September 21, 2011 at 7:50 am #359393funkyboogy
cheers guys
martin why would inlet valve stop it from finishing cycle ?
cheers ally
September 21, 2011 at 8:02 am #359394Martin
funkyboogy wrote:martin why would inlet valve stop it from finishing cycle ?
Good question Ally, so let me turn that around and ask, do you know that it has? Any error code that comes up invariably means the machine doesn’t want to play and could stop at any random point. I believe F27 relates to water inlet so perhaps either valve, water block or water supply problem related likely?
September 21, 2011 at 8:17 am #359395funkyboogy
cheers martin , i havent got the fault codes for these things – its just its a bit weird that it chooses to through up fault with 1 min to go .. i was think more on the drain side etc ..
ally
September 21, 2011 at 8:31 am #359396funkyboogy
just had a look for valves – seem they come complete with aquastop assy .. bit excessive if you only require valve
ally
September 21, 2011 at 11:37 am #359397Martin
funkyboogy wrote:bit excessive if you only require valve
Cor blimey I’ll say! At about £55 trade a risky punt if that doesn’t sort it. Smurfing the web thru Google (F27 Siemens) the consensus puts the blame both on the inlet valve and the analogue pressure switch… :hmm:
September 21, 2011 at 7:08 pm #359398suedehead1
i would be blowing down that pressure switch tube first if it was me.
September 21, 2011 at 7:32 pm #359399nomadPaul
F27 is shown as ‘pressure switch defective’
September 22, 2011 at 7:52 am #359400funkyboogy
cheers
will try pressure switch hose block etc 1st
ally
March 29, 2012 at 8:49 am #359401Bryan
Hi ally
Did you get this fault sorted?
I have a call this afternoon with identical fault description and any update would be appreciated.Thanks
Bryan
March 29, 2012 at 5:10 pm #359402funkyboogy
hi bryan
i honestly cant remember what outcome was – will try and rake about the grey matter and see what comes out ..
lol ally
March 29, 2012 at 7:02 pm #359403Bryan
Ok, job was cancelled, customer is going to contact Siemens as he thinks it’s still covered by 5 year guarantee.
Would still be interested in any solution for future reference….. if the old memory clicks into gear.
