Can anybody help. We have a siememes iq300 SN26M253GB/43. It only seems to allow approx 200ml of water into the holding tank attached to the side of the dishwasher, the diswasher attempts to draw water and starts to cycle but is just running dry.As a test I filled the tank manually with a hose and the diswasher draws and works perfectly but depleaetes the water once again only letting approx 200ml of water into the tank on each draw.there are no blockages I have removed the fill hose to the tank and turned the machine to a cycle and the pipe shoots out approx 200ml of water before shutting off.Any ideas please.TIA :rolls:
Hi. there is a side water chamber panel and a pipe underneath that blocks up on theses. If you remove the left hand panel of the machine and the front bottom plinth you should be able to find the problem. be careful.
