Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Siemen Integrated Microwave Issue
- This topic has 7 replies, 2 voices, and was last updated 6 years, 4 months ago by
Manhattan24.
December 8, 2019 at 10:30 pm #96850
Manhattan24
ParticipantHi,
Unfortunately while using my Microwave today it just stopped midway through with a complete loss of power. I replaced the fuse in the plug but that didn’t do any good. I just wondered if the internal fuse might need replacing or if there was anything else I could do to try and fix it? If it isn’t worth repairing, any advice on a suitable similar replacement would be very much appreciated.
The Microwave is Siemen Model No. HF-25M560B/02
December 9, 2019 at 12:04 am #465034electrofix
Moderatoryou could try the internal fuse anything else is a professional job
December 9, 2019 at 12:50 am #465035Manhattan24
ParticipantThanks for the reply.
I shall try a new fuse in it and hopefully that will do the trick. I think the microwave might have shorted out because I was warming plates in it, but I did put a small bowl of water in at the same time.
December 9, 2019 at 1:30 am #465036electrofix
Moderatoryou cant warm plates in a microwave they only heat water so yes you may have destroyed it
December 10, 2019 at 6:27 pm #465037Manhattan24
ParticipantI managed to get the cover off the microwave, but couldn’t locate the fuse. I just wondered if you had any ideas where to look for it? The power cord is at the bottom of the machine, so I would assume it wouldn’t be far from there. I did try to find a diagram or service manual but couldn’t find anything on Google. Also, video guides on YouTube all seem to be non-integrated machines.
December 10, 2019 at 8:39 pm #465038electrofix
Moderatorcant find it on any parts lists
follow the cable in and see where it goes
check door switch unit and main board
there is also sometimes a small board to filter out interference on some microwaves
December 14, 2019 at 4:40 am #465039Manhattan24
ParticipantThanks for the advice.
Unfortunately after removing all visible screws on the back of the machine the panel seems completely immovable. It looks like it’s connected to the top and front, which I think would require dismantling. Before giving up and buying a new one, I thought I would post a few images that perhaps you could look at to see if there was an easier way to find the offending fuse.
Link to photo – https://ibb.co/82WcMkB
December 14, 2019 at 10:11 am #465040electrofix
Moderatormost of the front panels once unscrewed lift up to unlock then lift off
