Siemens 3583 Door latch or interlock problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens 3583 Door latch or interlock problem
  • #20851
    Kilronan
    We have a Siemens Etraklasse 3583 which is giving problems when starting the programme.
    In order to start the programme you have to slam the door hard or thump the door. This only works after a delay of several minutes from setting the wash programme dial.
    Is the problem to do with the door latch ? or is it the door interlock ? I would welcome advice please.
    After the machine has washed, the we are able to open the door without problems.
    Is it a repair that I could do myself ? ( I am a reasonably competent DIY er )
    #188564
    matkins
    Re: Siemens 3583 Door latch or interlock problem
    Would suspect Door Interlock problem, Bosch OPN 056762, Remember Power OFF :zap: before repair.
