Siemens 84E562GB microwave, cuts out after about nine seconds
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens 84E562GB microwave, cuts out after about nine seconds
  • #97845
    mic
    This stops microwaving after about nine seconds and resets itself, it is cooking for this time as a cup of water heats up after a few tries. If you unplug the supply to the inverter it cuts out after 3 seconds as they normally do. Be grateful for any ideas.
    Siemens 84E562GB microwave.
    #469783
    snig
    Check for arcing in the cabinet. Remove glass base and check around all seams. Not always easy to spot. Found this is more likely to occur when only a small load in the oven, ie testing with a small cup of water rather than a big jug
    #469784
    mic
    Thanks,
    will get this checked out, no obvious arcing sounds.
