Hoping for some guidance on my recent second hand purchase of this Siemens unit, model number KA58NA40GB .
Noticed freezer would only get to minus 15 degrees C when set at minus 22, even after 24 hours. Found that the rear evaporator fan was goosed so replaced that, cleaned up the coils etc. Internal fan fine, door seals fine.
Freezes ice fine but as the optimal freeze temp is minus 17 really need this sorting. Coldest fridge will go is 4 degrees,even when 2 degrees is set.
Compressor comes on and off so presumably it thinks its getting to the requested temp, so could this be a thermistor problem, if so, the sensor inside the freezer wall looks difficult to replace, there is also one on the coils behind the inside panel which one? or could it be the main PCB module, or is there one behind the control panel?
Many thanks
