Hi guys,
Siemens SE65E330GB/35 FD8404 Type S9J1S
I have been out to this appliance today with a drain fault. Checked all the normal places that could cause the problem. Managed to select reset on the control panel and confirm the End LED lights up. Attempted a different wash cycle but it seems to be stuck in a wash cycle where it heats but fails to drain. Removed the side panels but couldn’t locate the drain pump, so can only assume this type of dishwasher has a dual spray/ drain pump. Any guidance would be appreciated… thanks
Spinfast
The pump can be located under the front lower panel mate . It has a seperate wash motor and drain pump – You will need to take off the lower front panel and the pump will be in front of you , just to the left of the sump.
Don’t forget, the pump impellor and rubber , non return flap valve can be easily accessed from inside the tub. Remove filter and at around 8’o’clock you will see an ‘L’ shaped cover secured by a single torx screw. Remove this to access impellor etc, watch out for bits of glass . 😉
