siemens aquastop faulty?
  • #57203
    deltra
    hi, model wxlm112gb, aquastop leaked,hole in it (mouse?) ordered new one(expensive 😯 ) fitted it today still no water intake, valves hum waiting for water, no voltage at power lead for aquastop, will it have blown control board ❓ or am i missing something 😳 anyone got a manual.
    #330237
    Turbo
    Re: siemens aquastop faulty?
    How come the valve hums if you have no voltage 😕
    Graham
    #330238
    nomadPaul
    Is there water in the base ?
    #330239
    boselecta
    had trouble with them before, throw it in the bin and put on a normal inlet hose.
    #330240
    deltra
    valve hums because it and aqua stop have seperate power supply.
    #330241
    S1MON
    boselecta wrote:had trouble with them before, throw it in the bin and put on a normal inlet hose.
    did the same worked a treat
    #330242
    Yeah we got that bit but as Paul asks….is there water in the base? Has the anti-flood device tripped. (those float microswitches can stick. 🙁 )….?
    It’s not a blindingly brilliant solution to overide the anti-flood facility by fitting a regular inlet hose. Especially if it’s in a first floor flat…!! It’s a bodge guys….come on now.! :rolls:
    #330243
    deltra
    no water in base,but i havent checked microswitch 😳 i will have a look tomorrow.. cheers.
