Siemens Model SE24M851.
I’m getting a “Check Water” LED light on when I run a daily cycle.
The cycle starts off running fine, it then after 15mins or so it “hangs” in a cycle of drawing in water and pumping it straight out.
The clock stops counting down, remaining on the same cycle.
I’ve checked the inlet and outlet hoses, the filters and taken off the pump cover to make sure it’s running ok.
When I did all this and ran it again (leaving the room), it flooded the kitchen floor. As I said I’ve checked the oulet hose but it seems to be pumping water fine. Any suggestions?
