Siemens CN633GBS1B Combi Microwave cuts out after several minutes.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens CN633GBS1B Combi Microwave cuts out after several minutes.
  • #101691
    Twoten
    I’m looking at the above combi-microwave oven.
    When using the microwave, the appliance switches itself off. The timer stops and the machine appears as if the on/off button has been pressed. The machine reverts to showing the time. The On/Off button does not stick.
    This can happen anything from 10 seconds to more than 10 minutes (intermittently).
    Sometimes the fault does not occur.
    When running it heats OK.
    Both fans run OK. When it cuts out it can be run immediately which suggests it’s not related to overheating.
    It’s similar to the Magnetron/Invertor board fault but I’ve never known this to be intermittent and the cut-out time is always constant.
    Any suggestions would be appreciated.
    #485717
    Hollytree_Technical
    Have you checked the insulation resistance of the elements?
    I have a Bosch one on the go with the same symptoms so just before christmas I disconnected the cooker elements as both were low (but not a fail) on the insulation resistance and it has apparently been running fine since then.
    Jem
    #485718
    Twoten
    Hollytree_Technical wrote:Have you checked the insulation resistance of the elements?
    Jem
    Insulation on the grill element was 24M’Ohm, do you think that would be enough to cause this?
    #485719
    Hollytree_Technical
    I don’t know but the one that I have been dealing with was down to around 3Mohm, it could be dropping when it warms up.
    Jem
