SIEMENS COMBI MICROWAVE
  • #75202
    funkyboogy
    MODEL HB86ES60GB01
    when microwave selected it starts up – coolinf fans runs – a few clicks etc from pcb kinda sounds like it works then cuts out ..
    any ideas ….
    #394204
    Re: SIEMENS COMBI MICROWAVE
    assume you got model wrong
    i got HB86E760B/01
    these units are panasonic based. if the unit does not produce microwaves it shuts down. ie you can set the time and start it but it will shut down after about 10 secs if the mag does not start
    cheapest option is the mag but if the invertor has gone estimate for changing both. have found the chapest place is ebay there is a guy in scotland and his prices cannot be beaten
    unfortunatly there is no easy way of checking which one had gone. i do it by swopping in a spare mag
    hope it helps
    funkyboogy
    cheers dave that’s exactly what its doing , ive got a panasonic microwave thats a scrapper – will try mag out of it ..
    this unit is also coming up in german – i take it i need to get manual to reset to english
