does anyone have info on these microwave /grill fan ovens , type HTHB86K E-nr HB86K580B /02 FD 8502 microwave wont work showing E10 error in display thanks
All the main bits are on the top. Once the top cover is off , the control board (inverter) is in the black casing at the rear centre . The relay board is front right – It’s quite obvious once you see it.
