Siemens compact dishwasher: drain(?) pump running continuously.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Siemens compact dishwasher: drain(?) pump running continuously.
  • #97777
    marklensman
    Something (drain pump?) is running continuously. Dishwasher got about halfway through cycle, then “remaining time” display stuck at 50 mins. My wife switched it off. No water inside when I opened it. Internal filters were clear.
    I tried turning on, pump started immediately. Tried turning off, turning on, then resetting – made no difference.
    The “en instructions for use” book has number 9000 236 264 (8701-1)
    Sorry, no model number remains visible on either label inside the front, both have faded away.
    #469436
    most dishwashers have anti flood systems, if any water gets underneath where the motors are there is a float that starts the pump and it wont stop till the water is removed
    marklensman
    … Please tell the model number if you can trace from the instructions number. I need to research even on how to get into the machine!
    #469438
    marklensman
    … but thanks for the prompt reply Dave!
    #469439
    well i would not order spares off this as we cant be certain but the works in this should be the same
    https://www.siemens-home.bsh-group.com/uk/supportdetail/product/SF44T553EU/15#/Tabs=section-spareparts/
    marklensman
    It certainly looks the same. Thanks again for your quick response Dave!
    #469441
    DanArt
    Hey Mark, I have the same problem and dishwasher. Did you find a solution?
    Dan
    #469442
    marklensman
    Sorry Dan, I was unaware of your post until today, one year afterwards, when I once again checked into the forum as the fault has returned.
    I can’t remember having done anything to the machine to clear the fault on the previous occasion. From memory, it had cleared itself by the next time I came to try fixing it – presumably once the water had dried out.
    I’m hopeful that leaving it for a while will be sufficient to fix it again, although clearly the source of the problem remains.
