Siemens Cond T/D Filter Light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens Cond T/D Filter Light
  • #49398
    Turbo
    Siemens Condensing T/D WTXL733C GB/05
    This dryer will run for around 10 mins then stops with the clean fluff filter alarm flashing. If you start it again it will run for another 10 mins etc.
    Door filter and condenser box are very clean.
    The drum sensors are quite worn but it even cuts out on 30min timed drying which makes me think the sensors are not the problem 😕
    Any help would be great.
    Graham
    #299778
    lerch
    Re: Siemens Cond T/D Filter Light
    Air flow problem ??
    #299779
    Turbo
    Could not see an air flow problem as the condenser box was clear both ways 😕
    Graham
    #299780
    Hammertime
    Hi Graham.
    Im sure you probably know this but its worth mentioning. Does it stop when the door filter is removed? If they have been using bounce sheets (or similar) it leaves an invisible film over the fine mesh of the filter and seriously restricts airflow.
    Not trying to teach my gran to suck eggs or anything, just a thought.
    H
