siemens d/w no display
  • #87305
    clockworkone
    se26n250gb/11. This dishwasher is not powering up at all. Checked on/off button. power going to board. It went mid wash. Don’t know a lot about this one to be honest and would appreciate any advice. Paul
    #434463
    melec
    Re: siemens d/w no display
    by operating the aquastop float switch this should power up pump which points to module failure
    Might be worth trying a continuity check on the Door micro also
    If the aquastop test does not run pump when door open the switch proved
    Methinks it’ll run door open or closed though
    #434464
    melec
    That should read ‘ then pump proved’
    It is usually module never a door switch but still have to check of course
