Has anybody been to 1 of these b4 or got any tech, been to 1 today that that the prog is far longer than it should be 4 instants on prog a quick wash should take aprox 30 mins but now the display shows 58 mins but takes much longer have checked 4 dry joint to pcb, blockages and 4 probs with the element could’nt any fault could anybody help thanks.
What usually upsets these is the metering hose, joining pressure unit on l/h side to sump, its a stiff ribbed hose about a foot long and o rings in.
Usually gets gunged up and sends it to oblivion. I would check and clean it.
Also, another symptom of the above is fill,stop,fill, stop causing banging in plumbing of house.
