Siemens D/W SN5M830GB/02
  • #69720
    dave-m
    Hey all, have one of these with what was an e15 fault, water in the base I believe, and so there was.
    Drained it and cleared the pump coz she said it also had e25 flashing up on occasion.
    It worked for a couple of weeks and now it has an e09 fault, which by searching here appears to be a heat pump/board fault.
    My question is how do I know which is gone?
    Took PCB out and no obvious damage and I took out the heat pump, the element part of which has 7 wires. First 3 have continuity, as do the last 4. I’ve not seen this type of heater/motor set up at all before so I’m not sure of any values or how I check which is gone before I order a part.
    The heat pump is not overly expensive so she may go ahead with e fix, but I’d like to know I’m ordering the right part.
    Cheers
    Re: Siemens D/W SN5M830GB/02
    dave-m wrote: I’ve not seen this type of heater/motor set up at all before so I’m not sure of any values or how I check which is gone before I order a part.
    Give me your email details and I’ll send you the manual. 😀
    #375766
    dave-m
    dave@dmappliances.com
    Much appreciated Martin
    #375767
    Check your inbox.:D
    #375768
    dave-m
    Got it, thanks again.
