Siemens dishwasher
  • #98148
    ChrisR
    Good morning.
    I replaced the drain valve on this dishwasher a few days ago but the E19 code has returned.
    Dishwasher stopped short of completing the programme leaving warm water in the bottom and not draining.
    Customer has since done a short programme and water has drained correctly.
    Any suggestions?.
    Thanks very much.
    have you checked the wiring back to the timer from the valve ?
    ChrisR
    The dishwasher worked fine for three washes after fitting the drain valve then e19 came up again.
    I’ll be going back in a couple of days so I’ll check board connections and the cabling to the valve.
    Have you come across this before Dave?.
    Thanks for the input.
    not had a repeat fault
    you could check the new coil for failure, long shot i know
    ChrisR
    Cheers Dave
