siemens dishwasher
  • #100652
    mikehha
    sorry boys and ladies ! dont have the model no; with me but that should not make much difference as bosch and neff use the same fault codes I have e24 coming up at the start of the program not all the time but about once in five or six starts ,now e24 is a drain issue there`s no restrictions, pump is fine but I have changed it.could this have something to do with the airgap or matrix and would low water pressure have an issue has any one had an e24 and if so what did you do to cure it..thanks.
    #481637
    mikehha
    has anyone come across e24 on any bosch neff or siemens dishwashers before.
    #481638
    is it on an extension drain hose ?
    mikehha
    no connects into a stand pipe by sink
    #481640
    well if its not too far down the pipe as it could air lock and your sure there is no blockages then it could be the pump
    Bosch dishwashers measure the pump current to determine if its empty. if the pump is worn it can draw more current
    they call it virtual sensors
    you could remove the pump and look for tightness or play
    mikehha
    I was thinking along the same lines so I put a new pump in worked fine for a couple of weeks then e24 again. so how do they know if the m/c is empty apart from the resistance on the impellor. also dose the fill side have somthing to do with it.
    #481642
    the fill side has the reed sw. that measures the number of pulses to determine water load. it cannot measure how much is in there
    this is the closest manual i have found on the later systems
    https://www.manualslib.com/manual/95…2u.html#manual
    interesting bit on the height of the outlet hose
